2 members (Joe H, Naturalthud),
196
0
Mod | | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Am trying to work on heater fan in my '53 Chev 3/4 T.--and it's darn cold up here.
Am I going to be able to get to the heater fan without removing the heater core? (It is a round core--) Or do I have to remove the heater core/fan as a unit?
At 7500 feet, it's cold up here with no heat!
Thanks in advance--T.K. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You will need to remove the core with the motor & fan, then you can remove the fan (easier said then done) by backing out the set screw and tapping off the fan from the motor shaft then remove the two nuts holding the motor to the core and install your new motor, nuts then fan and your ready to put it back in the housing and reinstall in your truck.
uhmmm all warm n toasty now | | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Appreciate the quick response and good info--will put on coveralls and go to work.
Thanks again--T.K. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Insure that you tighten the set screw, and maybe use some locktight. Mine backed off and allowed the fan blade to get it to the core, causing damage, resulting in a trip to radiator doctor. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I pulled mine to upgrade to a 12 volt. I bought the new motor from Brothers but the studs were off by about 1/32 on an inch or more. Rather than jerryriging it I sent it back. I have not reordered from another vender yet. If anyone has bought a 12 volt heater moter and had it fit let me know.
~Jim
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | The one I used was made by Enerco.I looked it up in the Carquest catalog by shaft size and style.I had to cut the shaft to length with a 4 inch cut off wheel.Works fine.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Big Chevy 3600,To add to the above.I found the part number for the blower motor I used.It was still on the motor,duh.The number is Unimotor #14576 (made by Enerco of Canada)It is 12 volt and can be wired for either rotation CC<--->C.Hope this helps!
| | | | | Joined: Aug 2006 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 31 | Thanks for all the good info--heater core at the shop, fan on the bench, snow falling.
Appreciate the help. | | |
