1 members (Mike Roache), 58 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#221347 12/08/2006 4:32 AM
Junior Member
Junior Member
I just became a new owner of a 1955 Chevy 3100 a couple of weeks ago. It has had quite a bit of work done on it, but needs plenty more. I have been searching for a site where useful information is exchanged, and think I have found it here.
I have a couple of quick questions regarding this era truck.
1. Is the heater fan supposed to run with the key off? (mine does)
2. Are the turn signals supposed to self cancel? (mine don't)
I have ordered some manuals for the truck, but can't wait to start wrenching. I hope I am not asking questions that have been beaten to death here.
#221348 12/08/2006 4:44 AM
Welcome to the 'Bolt.
to answer your questions #1-No, the fan shoud not be on with the key off. Most likely the wire is connected to a constant live feed instead of a keyd one.
#2-The signals should self cancel. The cancelling cam is probably worn or bent. Could also be a mis-alignment of the mechanisme in the housing, but that's unlikely. You can get a new cam from any of the parts suppliers, I got one for my '55 from American Classic (see link at top of page).
Don't worry about asking questions if you can't find the answer. If/when you can, post some pix.
Bill Burmeister
#221349 12/09/2006 12:31 AM
LONGBOX55s answer about turn signals is correct if it has a factory switch in it. If it has the add-on switch they won't self cancel unless there's a little wheel rubbing against the steering wheel. Confused now?
By the way, welcome to the World of Stovebolters.
#221350 12/09/2006 5:13 AM
Junior Member
Junior Member
It is the factory switch. Turn signals will have to wait until I get some heat out of it. I am not getting any hot water to the core. I must have a stuck/broken valve. After I figure that out, then I can chase down the fan wiring so it turns off with the switch.
The World of Stovebolters seems like a very nice place!
#221351 12/09/2006 5:19 PM
Just remember, the World of Stovebolting grows on you and then consumes you. To quote a popular song; "you can check out but you can never leave." But then, who would want to? grin
Welcome to the 'bolt and have a great time with the truck. And as someone else mentioned; pics, man, pics.
Jim Blake
Help support the Leukemia & Lymphoma Society (www.lls.org) through Team in Training (www.teamintraining.org). Help put a stop to ALL cancers.
My truck: '49 3800 Stakebed/Dump
#221352 12/09/2006 5:24 PM
Welcome to the 'bolt... good advice above.
Another quality post.
Real Trucks Rattle
#221353 12/09/2006 5:54 PM
welcome, and you can take what they say to the bank
Redryder pix
My Hotrod
#221354 12/09/2006 6:18 PM
Welcome aboard Newb. Signal canceling is as stated above. The only thing I can add to your heater switch question is that it indeed would depend whether your hot wire is at a switched location or not. My 59 recirculating heater switch, the rotating one, was wired constantly hot therefore it would have to be manually switched off. Only problem I ever had is when I used the low speed and it was so quiet I left the truck only to return to a dead battery. Only took a time or two for me to always use medium or high speed.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#221355 12/10/2006 12:32 AM
Welcome to the bolt, new guy.
I can't even begin to tell you the amount of help that I have received form the people on this site.
Advice, parts, you name it and someone has the answer for it.
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
#221356 12/10/2006 3:16 AM
WELCOME TO YOU AND YOUR TRUCK!!!
"The Lord is my shepherd"
#221357 12/10/2006 12:23 PM
I can't add to what has been said about your questions, BUT: Welcome aboard!
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#221358 12/10/2006 10:46 PM
Junior Member
Junior Member
Thanks to everyone who has responded and sent regards. I did get the heater working and the fan to turn off with the switch. I also got the turn signals to self cancel. Yesterday was a good day.
I did take some pics yesterday (in a brief break from the rain) and posted them on my web site. I think I have linked it in my signature.
Thanks again, this is a great site!
#221359 12/11/2006 8:44 PM
Man-that's a great lookin' truck! Welcome to da zoo!
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
