0 members (),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | How can I determine what kind of transmission I have. It's on a 1954 inline 235cc full pressure engine. I saw on different threads mentioning "T5". It almost sounds like the "T5" is a standard tranny for these old girls. I've never worked on trannys before and not sure if I will on this one. Rather leave to someone who knows what there're doing. Has anyone rebuilt one of these before? If so, how difficult is it and are the parts available? My mechanical knowledge is pretty sound and I'm sure I can do it, just wish I had done it before!
Thanks for any input,
~Ron | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | mummdogg, I enclosed a link that will show just about any transmission you might have. The new, modern T5 shown does not have its tailshaft on...it would be quite a bit longer. The standard heavy duty transmission for the rig you noted would have been the SM420. It is a 'top loader'...the shifter is on the floor. I don't think a three speed transmission is shown on the link. It would of course be your 'three speed on the column'. I hope this is helpful. http://www.novak-adapt.com/knowledge/transmission_gateway.htm Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you are refering to the 6400 in photo,s it more than likely is the SM420 4 speed with granny low. They are easy to rebuild. Get a good manual & follow directions. The bearings , gaskets & seals are readily available but if you need any hard parts you will probably have to find used ones or get another one for parts. The T-5 you see mentioned is a 5 speed used in s10 pickups & other vehicles. A lot of us are putting them in the light duty trucks to get the o-drive feature. It would not stand up in a heavy duty truck. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | I had a 49 3/4 ton once that had later 235 in it with a Clark 5speed behind it. Sure wish I'd kept that truck. I gave the darn thing away.  | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Thanks guys for the info. That's exactly what I wanted to hear. Stuart, the link you attached is awesome. I already put it in my "truck" folder. Very useful. I also did a Google image search for "SM420 4 speed transmision" and it showed where I can get the casting number. When I locate mine, can you guys check to see exactly which kind I have for me or is there a website simillar to "Inliners" I could check myself? On the link Stuart attached, the SM420 is the only transmission available for the 2-tons in 1953. Is that correct or are their others. The SM465 and the NP435 look simillar but were available in later model trucks.
BTW, the pictures on the link show the SM420(135 lbs) is a monster of a tranny compared to the T5(60-70lbs)!
Thanks alot, ~Ron | | | | | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | I'm in the process of rebuilding an SM420. There are rebuild kits available that include all the bearings, seal(s), gaskets, synchronizer rings and misc. small parts. You need a variety of special tools, but the work is not difficult.
Simplicity leads to reliability.
| | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | Polarcat, On that SM420 tranny you're rebuilding, does the speedo drive gear run off the the main shaft? What vehicle are you going to put this tranny in? Thanx. | | | | | Joined: Aug 2005 Posts: 39 New Guy | | New Guy Joined: Aug 2005 Posts: 39 | ShovelheadDon1200cc,
In a way it runs off the main shaft. The gear engages in a worm on the U-joint flange, which of course sits on the main shaft.
The tranny is now in my 1952 GMC 1 ton, and it runs beautifully.
