3 members (Nick in Manitou, TexasA&M48Truck, Hotrod Lincoln), 191 guests, and 2 robots.
Topics128,082
Posts1,055,964
Members48,430
#221164 12/06/2006 12:13 AM
Apprentice
Apprentice
Okay, so I'm looking through this catalog of truck parts, and while gazing at a suspension picture, I realize that I am looking at a part that my truck doesn't have! My 65 C10 came to me with the stock drum brakes all around, and I would imagine that a sway bar wasn't all that necessary with them, but I'm converting my front end to disc. Do I need to look into this?
Thanks as always,
Randy
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
#221165 12/06/2006 12:37 AM
They really help in cornering. One from a 67-87 C10/20 will fit no problem, cheap in the boneyard. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#221166 12/06/2006 5:05 AM
Z
Z Offline
the later lower a arms are drilled for a swaybar.my 64 wasn't but the 1980 front end i installed was.i just used the bar for the 80 and mounts from early classic.
#221167 12/06/2006 3:55 PM
I bolted a sway bar into my 66 GMC.... don't remember if i had to drill holes or not... it seemed to corner a bit better tho, and not sway so much on the freeway...
Another quality post.
Real Trucks Rattle
#221168 12/06/2006 6:22 PM
Have them front and rear on my 62, still have the drum brakes. corners like a sports car. good investment
#221169 12/07/2006 5:21 AM
Apprentice
Apprentice
Well! "Get 'em" seems to be the concensus here, so I think I'll look into it! My A-arms are already drilled for it so why not! Thank for the opinions, folks!
Randy
