7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Okay, so I'm looking through this catalog of truck parts, and while gazing at a suspension picture, I realize that I am looking at a part that my truck doesn't have! My 65 C10 came to me with the stock drum brakes all around, and I would imagine that a sway bar wasn't all that necessary with them, but I'm converting my front end to disc. Do I need to look into this?
Thanks as always, Randy
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | They really help in cornering. One from a 67-87 C10/20 will fit no problem, cheap in the boneyard. Brian | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the later lower a arms are drilled for a swaybar.my 64 wasn't but the 1980 front end i installed was.i just used the bar for the 80 and mounts from early classic. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I bolted a sway bar into my 66 GMC.... don't remember if i had to drill holes or not... it seemed to corner a bit better tho, and not sway so much on the freeway...
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Have them front and rear on my 62, still have the drum brakes. corners like a sports car. good investment | | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Well! "Get 'em" seems to be the concensus here, so I think I'll look into it! My A-arms are already drilled for it so why not! Thank for the opinions, folks!
Randy
