0 members (),
122
Mod | | | Forums66 Topics128,184 Posts1,057,266 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | The gas tank in my 46 Chevy 1/2 ton is leaking and has several small rust through holes in it. Is there a good replacement (stock) available out there? Has anyone had their tank restored with a product call Renu? My stock tank straps were missing, are there replacements available for those as well? Any comments are welcome. Thanks, Possum | | | | | Joined: May 2004 Posts: 191 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 191 | I've got one that's leaking as well. I'm thinking of trying JB Weld on the pinholes and sealing with a Tank sealer from Jim Carter. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | You can clean the tank, braze the holes shut and coat the inside. If the holes are pinholes the coating will plug them without brazing. Follow the coating manufacturer's instructions exactly. The coating will probably fail if you don't. I prefer RedKote coating. If you use the search function at the top of the page you'll find a ton of info on cleaning and coating your tank.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | As for the straps, there are replacement straps available, but you can use an old bike inner tube and that metal strap material with the holes in it for a fraction of the cost.
Fumblin46 used it and it worked like a champ. | | |
