6 members (50 Black, greenie-reddy, 60steve, 52Carl, GradyB, cmayna), 133 guests, and 5 robots.
Topics128,204
Posts1,057,294
Members48,467
The gas tank in my 46 Chevy 1/2 ton is leaking and has several small rust through holes in it. Is there a good replacement (stock) available out there? Has anyone had their tank restored with a product call Renu? My stock tank straps were missing, are there replacements available for those as well? Any comments are welcome. Thanks, Possum
I've got one that's leaking as well. I'm thinking of trying JB Weld on the pinholes and sealing with a Tank sealer from Jim Carter.
Ex Hall Monitor
Ex Hall Monitor
You can clean the tank, braze the holes shut and coat the inside. If the holes are pinholes the coating will plug them without brazing. Follow the coating manufacturer's instructions exactly. The coating will probably fail if you don't. I prefer RedKote coating. If you use the search function at the top of the page you'll find a ton of info on cleaning and coating your tank.
As for the straps, there are replacement straps available, but you can use an old bike inner tube and that metal strap material with the holes in it for a fraction of the cost.
Fumblin46 used it and it worked like a champ.
