0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Question for you Task Force guys: what years 3 speed manual column shift will fit a 55.2 3100? The reason I ask is because my dad wants to convert his 4 speed floor shift to a 3 speed column shift and I want to know what I'm looking for before I post a parts wanted ad. I would guess 55-9 would be the same, but thought I would ask. We already have the 3 speed, just need the complete shift assembly. It's a 265 v8 if it matters at all. Thanks... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, any model conventional cab 55-59 will have what you need, engine doesn't matter
Bill | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There is a difference in the linkage from v8 to 6 cylinder. The '55/'56 have a 2 peice shift rod and a bellcrank for 2nd/3rd gears. The shift arm on the trans is also inverted compared to the v8 trucks.
Bill Burmeister | | |
