4 members (Gdads51, Hotrod Lincoln, artinva, RoadsScholar), 62 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#220722 11/30/2006 1:00 AM
Question for you Task Force guys: what years 3 speed manual column shift will fit a 55.2 3100?
The reason I ask is because my dad wants to convert his 4 speed floor shift to a 3 speed column shift and I want to know what I'm looking for before I post a parts wanted ad. I would guess 55-9 would be the same, but thought I would ask. We already have the 3 speed, just need the complete shift assembly. It's a 265 v8 if it matters at all.
Thanks...
Steve
'49 3800
'52 3600
'57 3100
yes, any model conventional cab 55-59 will have what you need, engine doesn't matter
Thanks Bill.
Steve
'49 3800
'52 3600
'57 3100
There is a difference in the linkage from v8 to 6 cylinder. The '55/'56 have a 2 peice shift rod and a bellcrank for 2nd/3rd gears. The shift arm on the trans is also inverted compared to the v8 trucks.
Bill Burmeister
