| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | I have a '59 1/2 ton panel. When I removed the rear brake drums I found that some of the parts were missing. There is a peice on each side that maintains the separation between the emergency brake mechinism and the brake shoes. I believe they are called "brake bars" and there are also springs that go with them. These are made of flat metal and are shaped sort of like an end wrench. I have not been able to find them in any of the catalogues that I have. Thanks.
Toxictiki
'59 Apache 3100 panel (235) '51 Chevy Fleetline Deluxe (216) '48 Binder KB-1 (flathead 6) '77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | tiki - those are called parking brake struts ["lever to primary shoe struts"] - not reproduced anyplace I've seen, so yer lookin for used, but the springs are available from any parts store if you've got one to match
Bill | | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | Thanks Bill, do you know what years of trucks are interchangable?
Toxictiki
