2 members (Oswald, Wayne67vert), 107 guests, and 2 robots.
Topics128,060
Posts1,055,839
Members48,427
#220583 11/28/2006 8:26 PM
I have a '59 1/2 ton panel. When I removed the rear brake drums I found that some of the parts were missing. There is a peice on each side that maintains the separation between the emergency brake mechinism and the brake shoes. I believe they are called "brake bars" and there are also springs that go with them. These are made of flat metal and are shaped sort of like an end wrench. I have not been able to find them in any of the catalogues that I have. Thanks.
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
#220584 11/28/2006 10:18 PM
tiki - those are called parking brake struts ["lever to primary shoe struts"] - not reproduced anyplace I've seen, so yer lookin for used, but the springs are available from any parts store if you've got one to match
#220585 11/29/2006 12:05 AM
Thanks Bill, do you know what years of trucks are interchangable?
Toxictiki
