Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (mo2cyl, panic), 59 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#220559 11/28/2006 4:18 PM
I finally stripped everything off the frame of my 54 and can see the middle crossmember just behind the cab is rusted pretty bad. I'm going to have to replace it. Does anyone know where I can get a replacement for it? This is the crossmember with the Steel gossets.
#220560 11/28/2006 4:54 PM
I'd suggest advertising in the parts wanted part of the swap meet for a replacement frame.
People trying to sell frames don't seem to get much for them, and I'm sure it would be less work to clean up another frame than to swap that crossmember.
And if you can't get a complete frame you may be able to get a used crossmember the same way.
#220561 11/28/2006 11:29 PM
Junior Member
Junior Member
Hey Morepower16,
I have a friend in Porter Texas that has one and has access to a couple more.
Vern
#220562 11/29/2006 12:41 AM
I see frames themselves go really cheap and pretty often to boot...might be better just to grab up a nuther one and start with sandblastin..
#220563 11/29/2006 2:09 AM
As you most likely already know, a '54 frame is different from earlier frames.
