8 members (walter74, mvigo, Forty9, Shaffer's1950, Rusted Nut, mick53, Wally / Montana, klhansen), 114 guests, and 2 robots.
Topics128,049
Posts1,055,740
#220543 11/28/2006 4:38 AM
I am working on parts from a '46 Chevy 1/2 ton. I have the steering wheel still attached to the column and gearbox. I was trying to take the horn button assembly appart so I can remove the steering wheel.
I know you have the horn ring on the bottom that has the 3 little notched posts that goes up through the steering wheel. Is that what is keeping the horn button in place? How do you unhook the horn button without breaking anything?
Chevman
#220544 11/28/2006 4:56 AM
just g-e-n-t-l-y pry it up. it kinda snaps into and outta place. ooops,,disregard,im thinkin of 47-54. although they might be the same?
#220545 11/28/2006 5:16 PM
Chevyman, The actual button unscrews from a contact plate, which is just under the button. The contact plate is held in place with a spring wire that wraps around the three pronges from the piece under the stearing wheel. After you take off the spring wire and the contact plate there is a nut that holds the stearing wheel on.
If you need some pictures of the horn assembly contact me directly and I'll email them to you.
Good Luck
George
