8 members (WICruiser, DaveV, Phak1, Jimmie D, dt235sd, Wayne67vert, NorCal52Suburban, Hambone), 76 guests, and 5 robots.
Topics128,179
Posts1,057,163
Members48,465
#220401 11/25/2006 4:51 PM
I have located a grille from a '54 Chevy. The VIN of this truck begins with N54F..., which I believe makes it a 4100 series truck, at the least. (The hood emblems are already missing, but it is definately a "BIG Bolt", with dual rear wheels)
Can any portion of this grille be used on a 3100 series truck?
The grille is in good condition and I hate to pass it up
I seem to remember this topic being discussed in the past, but I am having some trouble locating where I saw the answer to my question.
#220402 11/25/2006 6:02 PM
although it looks the same,,its bigger. if you park the two trucks side by side,,youll see the difference.
#220403 11/25/2006 7:22 PM
jfjbjr,
I responded to a similar question awhile ago stating the same opinion as delux54panel ....I think I was wrong. The front wrap is larger, but I believe the grille is the same for all sizes. smile
Stuart
#220404 11/25/2006 7:26 PM
If you look in the factory assenbly manual and compare part numbers you can see that only a couple parts are interchangeable. But for the most part it is larger.
My Trucks
Stuff I Collect
#220405 11/25/2006 10:13 PM
I have to correct myself, after checking the numbers again, it appears that none of the parts are interchangeable.
My Trucks
Stuff I Collect
#220406 11/27/2006 4:26 AM
I know the grilles are not interchangeable. I had a '54 pickup and bought a grille from a 2 ton. It wasn't even close, the big truck part was about 4" or more wider than the pickup one.
#220407 11/27/2006 4:48 AM
#220408 11/27/2006 5:27 AM
Sheesh, I guess the verdicts in...they ARE different!
Stuart
#220409 11/27/2006 3:33 PM
I brought the '54 / '55 grille home and set it on the floor, in front of my 3100 series truck. From one angle it looks like it might fit, but from another angle it looks BIGGER.
What makes it more difficult to tell is that one grille is mounted on the truck while the other is not, making it hard to accurately measure. One grille is chorme and the recent find is painted.
Anyone need a painted grille for the larger series '54 / '55 truck?
Thanks for all the advice!
