1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | I have assembled the body and rad at the front end and I noticed that it appears that a metal fascia is missing, because I have no picture of what the front end should look perhaps someone can let me know if the part actually exists. At the op of the grille where the hood grasp is and to the support bracket that is above the rad, I think is esthetic shroud between the two to cover part of the rad if viewing from the front. There is bolt holes at the bracket and bolt holes on the hood catch shroud. Its difficult to describe. 1950 GMC 1-ton pick-up. Thanks for any help! | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My '54 G.M.C. has the part you describe. It is formed sheet metal and is a closure from the part holding the hood latch and the radiator core support. It is a compound curved part and would be very difficult to replicate, keep looking for a factory made part, shouldn't cost too much if you can find one. | | | | | Joined: Jan 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 35 | Thank you for the confirmation, I'll begin the search, Cheers! | | |
