5 members (jmoore, Bill Hanlon, 3B, 54farmtruck, Phak1), 95 guests, and 1 robot.
Topics128,188
Posts1,057,329
Members48,469
I have assembled the body and rad at the front end and I noticed that it appears that a metal fascia is missing, because I have no picture of what the front end should look perhaps someone can let me know if the part actually exists. At the op of the grille where the hood grasp is and to the support bracket that is above the rad, I think is esthetic shroud between the two to cover part of the rad if viewing from the front. There is bolt holes at the bracket and bolt holes on the hood catch shroud. Its difficult to describe. 1950 GMC 1-ton pick-up. Thanks for any help!
My '54 G.M.C. has the part you describe. It is formed sheet metal and is a closure from the part holding the hood latch and the radiator core support. It is a compound curved part and would be very difficult to replicate, keep looking for a factory made part, shouldn't cost too much if you can find one.
Thank you for the confirmation, I'll begin the search, Cheers!
