| | | Forums66 Topics128,105 Posts1,056,209 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | My cab and front end are off a 1940 Chevy firetruck. Are my fenders the same part # as those on a 1940 Chevy 1/2 ton pickup? Thanks from a newbie John | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Probably not. Was the fire truck bigger than a 1 ton? I think the wheel openings are bigger on the bigger trucks. Take a spin through the gallery.
If you look at the 1.5 ton shown, it appears that the openings are bigger.
That is the case with the 41-46's as well. | | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | The Vin starts out 14W801 and it had dual wheels. The PA title had a 11,000 GVW. | | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | The Vin decoder says it was built in Baltimore Md as a 1.5 Ton 158.5" wheelbase. I asked about the fenders because I was concerned that if I center my fenders over the S10 wheels and then upgrade to new fiberglass fenders later...will it thow everything off center? | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | I'm not absolutely sure, but I think my 46 one-ton Panel has larger wheel openings than the 1/2 & 3/4 ton trucks. Here is a pic with 30 inch tall tires on S10 suspension. The tires still look too small IMO. http://www.enzoco.com/mike/truck/part3p3.htm Can anyone with a 41-46 1/2 ton confirm this for me? Did the 1/2 ton trucks have smaller openings than the one-tons? Cheers, MV | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | John,
I can't say for sure exactly on your 40, but I put a set of big truck fenders on my 41 that i used to own. In the case of my 41, centering the wheels would have been more a little more difficult on a frame swap due to the large wheel openings. The space needed for the bigger tires made the litte 14 inch rims I was running look terrible. When I changed back to 1/2 fenders, the 14 inch rims looked more normal with a tire with a taller stance...the big truck fenders were just did not fit the look or the build. My 41 was more of a street rod than the truck I am doing now. The clearance with the ground did not look right either..1/2 fenders made it look a little like it was more in the dirt up front.
I guess what I am trying to say is..if you are doing a frame swap, I would get the correct fender first to make sure you get the look you want. It would be hard to go back and move everything on a frame swap if the look is not right due to the large fender openings.
Even if you found a steel fender in dire need of repair to use as a mock up, you might be money and time ahead...
my $02... | | | | | Joined: Nov 2006 Posts: 37 Apprentice | | Apprentice Joined: Nov 2006 Posts: 37 | Thank you both for the help. I will get my ducks in a row before I spend more money on parts. The S10 is a 2000 ZR2 4x4 extended cab. The only good thing I see so far is if I use a 3/4 ton box the wheelbase will be perfect without cutting the frame. The tires are brand new 31 x 10.50 15s. Maybe that will help fill up firetruck fenders. | | | | | Joined: May 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 145 | It sounds great. Be sure and take pictures. We love pictures! Cheers, MV | | |
