9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd), 75 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#21990 07/27/2004 12:22 AM
JD5
Offline
When shifting my 49 Chevy 3 speed from 2nd to 3rd gear I usually have some grinding of the gears. Sometimes if I shift slowly it won't grind or the grinding won't be as severe. What is the fix for this problem? Should I rebuild the transmission while trying to fix the problem?
JD
#21991 07/27/2004 12:46 AM
Hey JD! My wife has a 50 1/2 ton that her grandfather gave her 15 years ago, and hadn't ran in about as long. When I got it going, it had the same problem, only it was also making a noise in first. I took it to Gale here in Joplin, and he told me that the trans was completely worn out. I ended up getting another one for around $125.00 Solved the problem. Yours may need rebuilt, but it wouldn't hurt to have someone take a look at it.
KT
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#21992 07/27/2004 2:47 AM
H Online: Content
The Chevy trannies do wear out, all over worse than anywhere else! You might get away with a synchronizer and a parts kit, needle bearings, gaskets, etc., but be ready to do a replacement if it's got many miles on it. The Furds used to tear up, and the Chevvies would wear out!
#21993 07/27/2004 4:37 AM
I don't know much but I do know when my '64 C10 linkage was out of wack (which happened often due to wear) it would do the same thing so I might check that first. Jess
1951 3100
#21994 07/27/2004 9:43 PM
JD5
Offline
Kthomas, In which shop does Gale work? Most of the people in Pittsburg won't work on an older vehicle so I've had to do most of the mechanic work myself.
JD
#21995 07/27/2004 10:20 PM
Riding in the Passing Lane
It needs an o-haul paying particular attention
to the syncro. These arn,t real hard to work on
if you follow the book. My partner has some used
ones if you want to go that way.
You can put 140 gear lube in there would help
some.
1972 Chevy c10 Cheyenne Super
#21996 07/31/2004 9:18 PM
JD5
Offline
I replaced the transmission gear oil with 140 weight oil. It did help some. I may still try to either replace or rebuild the transmission this winter.
JD
