4 members (NJC, fonz8261, Southerntruck, J Lucas), 141 guests, and 3 robots.
Topics128,089
Posts1,056,442
Members48,443
#219915 11/17/2006 4:49 AM
Rebuild project moving along slowly---
This might be a dumb question --- I had the back end up on jack stands, with wheels free. I started the engine, 4 speed manual in neutral. Idling smooth, the drive shaft spins one of the rear wheel slowly. This seems odd to me --- what's up?
Internal friction in the trans. is the answer, it is nothing to worry about, it is perfectly normal.
Try stopping it with your hands. bet you can.
chevyman had it right.
gear oil is sticky, so it rotates other trans parts, thicker the oil the more resistance it has. Thats why the new manual transmissions use 10wt or 30wt oil nowadays. (mechanics refill them with 30wt non detergent)
64 & 66 GMC long fleetside 4x4
Cartwright, OK
