2 members (BC59, Uncles51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | What is the normal range for the fuel guage in a 66 C-10? Is it supposed to travel the full distance from E to F? When you read mine the marks at 1/4 tank is bone dry empty and 3/4 is full. If that isnt the normal range, how do I get it to travel the full range of the guage? I have the warning light guage panel in my truck. Thanks | | | | | Joined: Mar 2003 Posts: 181 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 181 | No, that's not the way they were designed, but it is normal. I can't say that any of the 6 64-66 GM PU's I have had ever worked right. The only way I know to adjust it is to tweek the float arm in the tank ontil it reads right. Other wise you just learn that when you get down towards a quarter tank, to find a gas station. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | It sounds like you may have a faulty gauge or sending unit, because the gauges in all three of my 1966 Chevrolets would go from F to E. However, due to my previous experience with GM gas gauges, I rarely allow them go below the 1/2 mark. I had a 1970 Pontiac that would read 1/4 when full and 1/8 when empty. I ran out of gas several times with that car. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Check the resistance of your sending unit. 30 ohms in the full position and 1-2 ohms empty. If it reads that your gauge is likely faulty.
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Where is the best place to get an OE style guage? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Post a topic in Truck Parts Wanted and you will get several responses.
The needle on the fuel gauge, whether in a gauge cluster or warning light cluster, should make a full sweep from emply to full, if working properly. I have several that work, as designed. | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Thanks guys, I just posted an ad for a warning light cluster fuel guage. | | |
