3 members (KCMongo, HelmutVonSchet, 59 fleet), 90 guests, and 0 robots.
Topics128,049
Posts1,055,679
#219830 11/16/2006 1:41 PM
Junior Member
Junior Member
Hi everyone, from Murraydog in the UK, I have a `49 Chevy pick-up, (3800) long wheelbase, rarer than hens teeth over here,( in fact it would appear that I own one of only three that are known of in the U.K.) and I appreciate that everybody has different ideas on how these vehicles should be treated, i.e. restored, rodded etc but I would be grateful if anybody has any information at all regarding the "grafting of a `73 Camaro front clip" onto my chassis
Thanks guys
#219831 11/16/2006 3:33 PM
welcome to the bolt,, I cant help you with your question but I am sure someone will chime in, some like them stock, modified, and in between..
tighten your belt.. you are in for a good ride here
here is a pix of one our folks with a 3800
click here
Redryder pix
My Hotrod
#219832 11/16/2006 3:55 PM
Jim Carters Truck parts (check links page) has some tech tips, they may have something. Also, Classic Truck Magazine and Custom Classic Truck have done articles. Check their websites.
From what I remember, the clip is cut horizontally, where the frame curves down behind the cross-member. The truck frame is cut in a curve to match. The most important thing to remember is, Measure, Measure, Measure, then cut (and hope you measured correctly).
Are you planning to change the rear axle as well?
Good luck
#219833 11/16/2006 8:30 PM
Junior Member
Junior Member
Quote
Good luck
#219834 11/16/2006 8:33 PM
Junior Member
Junior Member
Thanks for the response, yes it will have a Ford 9" rear axle mainly because it`s got a 460 Thunderbird engine and whilst I would love a 454 Chevy, you have no idea how much they fetch over here, upwards of $5000 and in need of rebuilding etc, I make no excuses for wanting to "rod" a classic truck but hope that you all understand the personal taste angle, great forum, nice to chat to fellow owners
Be Lucky
Murraydog
#219835 11/16/2006 8:37 PM
Junior Member
Junior Member
Quote
Be Lucky
Murraydog
#219836 11/16/2006 8:38 PM
Junior Member
Junior Member
Sorry, excuse my stupidity, I`ve just seen that you are in the UK as well
#219837 11/16/2006 9:59 PM
just a tip.........if you need to edit just click on the pencil/envelope (last block on top)... you can edit/delete..
Redryder pix
My Hotrod
