| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 23 | I am in the process of putting my 1949 3600 back together and need some advice for assembling the bed.
I am not sure if I should put the metal together and mount to the frame and then install the wood floor....or should I put the entire bed together including the wood floor before mounting to the truck?
Any suggestions? Better yet, anyone have a step-by-step guide as to how to go about this?
Thanks, Spencer | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | check in the bed section
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=forum;f=41
lots of advice and you can get the installation instructions from mar-k.
also tom brownell's "how to restore your chevrolet pickup" has a section about bed assembly. | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | My '37 bed is mounted on the cross members which are heald in place by the wood. The sheet metal is only mounted to the frame at the very back. Joe | | |
