5 members (Otto Skorzeny, Wickedbass, Hanks custodian, 32Fordpuchoptop, Gdads51), 67 guests, and 2 robots.
Topics128,094
Posts1,056,048
Members48,433
#219702 11/14/2006 4:38 PM
When you have to combine 2 or 3 different grilles to make a good grille for one of these trucks, what does everyone do for the center fastener that is originally a rivet? Just use a bolt in the center? Anyone have any advice?
Thanks.
Scott
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#219703 11/14/2006 8:18 PM
Anonymous
Unregistered
Anonymous
Unregistered
Bottom of this page Cater\'s catalog page
#219704 11/14/2006 10:58 PM
ODSS President
ODSS President
This may help someone. The grill bars are not the same size and can not be interchanged on the same grill. Top to bottom they are smallest to largest.
~ Cosmo
1949 Chevy Half Ton
#219705 11/14/2006 11:25 PM
Original grille bars usually have a number stamped on them to indicate where they go. The numbers are one through five and stamped on one edge. I haven't looked at mine for awhile, so I can't say if the one is the top bar or the bottom bar..
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#219706 11/15/2006 4:39 AM
I think the answer to your question is, use a pop rivet, they're cheap and effective.
#219707 11/15/2006 5:16 AM
Hi!
Pop rivets will probably work fine. 20 years ago I removed all my bars and reassembled them with small machine bolts and nuts. It is still holding together just fine. Yes, the bars are all different lengths as noted above.
Good Luck,
littlebuddie
1948 AD Pickup
#219708 11/15/2006 5:24 AM
Anonymous
Unregistered
Anonymous
Unregistered
Quote
Original bars have notches (except the top) one for #2nd from the top two for third from the top and so on not numbers aftermarket bars have stamped numbers
#219709 11/15/2006 9:03 PM
thanks for the help!
1967 Chevelle 300
#219710 11/16/2006 3:35 AM
Yep he's right,don't forget me scott !!!
1951 3100 Chevrolet
Moderated
Moderated
Can someone just give me the step by steps to change out my 53' chev. pickup grill? my email is [email protected] sure could use some help......
Former BMW Rider
Former BMW Rider
Mike,
Give this LINK a try. It should do the job, good luck!
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Is there an easy way to install the grille in the front clip after the clip is installed?
Handy, tknx for the link
Weeds
Don't understand the question.
If the clip is completely installed, it's like doing a grill R&R due to accident damage. All the screws and bolts are accessible (taking out the upper pan is helpful).
If you are building the clip in place or putting one back that was removed in one piece, you may have to loosen a few more bolts to get it in and aligned, but the grill is installed near the end of the build anyway.
Best to get a fastener kit like - http://www.oldchevytrucks.com/cart/product.asp?prodid=FP165&i=19294|||||
Many pop rivets are aluminum. You put aluminim next to steel and add a little moisture you get electrolysis and it will eat up the parts.
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
