1 members (Eileen),
99
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 13 New Guy | | New Guy Joined: Feb 2006 Posts: 13 | Where are the cast codes on the small-block Chevy engines? Trying to find out if I really have a 283.
Thanks | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | look just above the oil filter, on the bellhousing flange
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Feb 2006 Posts: 13 New Guy | | New Guy Joined: Feb 2006 Posts: 13 | | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The casting code is on the left side of the distributor hole, right where the bellhousing meets the engine. The casting date will be on the opposite side.
It can be hard to see because of how close to the firewall it is. It usually is covered with dirt and grease too.
The pad on the front of the engine should be stamped with the assembly date. The first letter is a designator for the plant (F=Flint) | | |
