2 members (JW51, TUTS 59), 133 guests, and 4 robots.
Topics128,089
Posts1,056,362
Members48,442
1 Offline
Where are the cast codes on the small-block Chevy engines? Trying to find out if I really have a 283.
look just above the oil filter, on the bellhousing flange
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
1 Offline
The casting code is on the left side of the distributor hole, right where the bellhousing meets the engine. The casting date will be on the opposite side.
It can be hard to see because of how close to the firewall it is. It usually is covered with dirt and grease too.
The pad on the front of the engine should be stamped with the assembly date. The first letter is a designator for the plant (F=Flint)
