5 members (RLB, 1955 1 Series, Thomaslb, 52Carl, Hotrod Lincoln), 105 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
#218713 10/30/2006 6:09 PM
I am in the process of restoring a 1941 GMC 3/4 steak bed. I am going to move the tank from inside to under the bed..... has anyone done this and what type of tank did you use? I found the demensions of a 54 chevy tank will fit where I want it to go. Just looking for more ideas and input. Also I need the leg room in the cab... I'm 6'6" so I'm redoing the interior. What has anyony used for seats that go all the way back against the back of the cab? Thanks for any input you might have. Dave.
What is your inseam? I'm a tall guy too. I fit my stock AD seat with it all the way back but when I used to have a '55 CJ-5 I couldn't get my knees under the steering wheel. I got some seats from Steel Horse and made new mounting brackets.
Either offroad or racing seats tend to have thin backs and upright seating positions and should work for you.
Good luck, though, the '41 cab is pretty small.
Paint & Body Shop moderator
No body seems to like the way I did my tank on my 54 G M C but I used a water preasure tank and mounted it on the left side under the flat bed. I used pipe fittings to make a filler tube and steel tubing for a pick up tube. It works for me.
I like old trucks
Use a beer keg. Put a high polish on it when the fab work is done and you'll have a real show piece,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I used a stainless steel LPG tank. Our Laws wont let me use it as a LPG tank. However i can use it for Petrol. Go Figure!
Brendon
