4 members (Robert Crandall, farmallb, Steelonsteel, Rick Brown), 149 guests, and 5 robots.
Topics128,108
Posts1,056,239
Members48,437
I HAVE BEEN LOOKING FOR A PAIR OF PARKING LIGHTS FOR MY TRUCK, BUT ALL I SEE IN THE PARTS CATALOGS ARE RECTANGLE SHAPED. ALL THE PICTURES I HAVE SHOW A ROUND LIGHT. WHAT GIVES?
1953 GMC half-ton
The Chevy and GMC park lights are different.
Chevy's are the square ones mounted in the grille.
GMC's are the round ones mounted in the fender. There were two different sizes, one from 47-51(I think). The other for 52&53.
I've been searching but I have yet to find a good set. I don't think anyone reproduces the entire light.
I ended up using the 55-59 parklights with white lenses. They are far to big for the earlier size, but the 52&53 size isn't to far off.
Good Luck.
That's about what I'm finding - a round lens and gasket that might work, but no complete assembly.
1953 GMC half-ton
On my 1953 3/4 ton GMC I replaced my lenses with the 1955/
57 amber cone style, they look "great" & they fit the old openings!
They are from Brothers, they carry them for around $34 per side for the whole assembly .
Chevy Duty does have the glass lenses for around $12 each
(part # 47-115), but not the assembly/just lenses. Now,
I have my old set that you can have for a small $ + shipping !
(Only problem, I'm in Eagle Rock & the GMC is in Woodland
Park Colo.) ! Let me know ...If you E mail me I can send you a shot of what they look like !
'53 GMC "Ranger"
I decided to order a pair of the '55 - '57 cone lights. Maybe check some junkyards in the spring.
Thanks all!
1953 GMC half-ton
Check out www.oldgmctrucks.com , join the discussion board. I'm sure someone on there will have these lights.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
May seem way out there, but my '60 AH Bugeye has torpedo lights on all 4 corners. When I get home I can see if they match the size on my 49 3/4T. Moss Motors carries replacements in amber and red. Must be lots of other cars that used the style, can't be very many sizes to look through.
Good luck.
