| | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21854 12/11/2002 3:26 AM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | Help, i got a 51 1/2 ton what engine do i have? head # 3836848 gm5 block# k2233 (behind starter) can someone help decifer this for me | | |
#21855 12/11/2002 4:46 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Look at the letters and numbers just below and forward of the distributor.
#21856 12/11/2002 11:20 PM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | ok all the info i got 3836848 on the head 3837004 on the block k2255 stamped behind starter also beneath both casting number is "GM5" was told is could be either a 55-57 chev engine or a gm from some year is there a way to tell gm from chev also anyone have the hp and torque on this thing | | |
#21857 12/12/2002 3:23 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's not a GMC, and it's probably a Chevy 235. HP is about 100-140 depending on who you believe and how you measure it. The head is the high compression 235 head. The '53 Corvette version produced 150 HP and 227 ft-lbs of torque with a more radical cam and triple sidedraft carbs.
#21858 12/12/2002 4:48 AM | Joined: Dec 2002 Posts: 1 Junior Member | | Junior Member Joined: Dec 2002 Posts: 1 | How do you know if The head is the high compression 235 head... Is it the GM#
Also...is there a difference between a blueflame 235 and any other 235s...
thanks.. | | |
#21859 12/12/2002 8:51 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, high compression is relative, I guess. The 3836848 head is the highest compression of all the 235 heads with the biggest valves and best flow of all of them. It's only 8:1. See casting numbers for more info. The list is not complete on the block castings. The Blueflame 235 is the car version with a fiber timing gear and hydraulic lifters and the Thriftmaster 235 is the truck version with aluminum timing gear and solid lifters. There is also a rare Corvette 235 with a hotter cam and sidedraft carbs. There is also an earlier splashoil 235 offered before 1953 that looks like a 216 and shares the dipper rods. It is referred to as the hi-torque or jobmaster 235.
#21860 12/13/2002 4:50 AM | Joined: Nov 2002 Posts: 3 Junior Member | | Junior Member Joined: Nov 2002 Posts: 3 | Your block and head casting numbers match my 1956 thriftmaster 235. It is rated at 140 gross horsepower. 128 net horsepower according the spec. plate in my door frame. However, your casting date, K2255 is different from mine. K2255 translates to the to cast date November 22, 1955 (K=11th month= November, 22 is the day of the month. 55 is the year).
1956Chevy3100
