| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#2182 11/19/2004 11:32 AM | Joined: Apr 2004 Posts: 84 Member | | Member Joined: Apr 2004 Posts: 84 | Installed rebuilt speedo bought from ebay. No gripes with the transaction, but it wont go past 40 mph. Odometer seems to work and a new cable was installed. Any ideas? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I got an idea you got screwed. Is the needle hanging on the face? If so maybe the shaft is bent. If not it's posible the spring that returns the needle is too stiff. | | | | | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | I had the same problem. These speedometers carry a slight magnetic charge. If yours was ever taken apart, it is very possible that much of the charge is gone. Take it to a speedometer shop, and they can recharge it for you. How did all this sawdust get under the hood? | | |
