3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#217965 10/17/2006 5:51 AM
Junior Member
Junior Member
Strange thing happened to me today. I have a good friend who runs a galvanizing business who has been so good to acid dip a lot of parts for me free of charge. He dipped frame and many other parts. Friday I took him five rims from the truck so acid could remove rust and old paint.
When I picked them up today someone had put them in galvanized vat and galvanized them. Not what I needed. The question is what can I do? Will sandblasting them rough them up enough to paint? Or should I start looking for more rims?
Mike Bolton
#217966 10/17/2006 12:16 PM
Why not leave them alone? Galvanized rims... that would be original.
#217967 10/17/2006 12:47 PM
I have had no luck with keeping paint on galvinized stuff.Can they not strip them? Would look kinda neet though.
#217968 10/17/2006 12:52 PM
You could use vari prime"self etching primer", then paint them. You should get great results.Call your local auto paint store.
1951 3100 Chevrolet
#217969 10/17/2006 1:05 PM
There is paint to hold on galvinized metal.
"It ain't a truck if you can't hose out the cab."
#217970 10/17/2006 1:13 PM
I have used a zinc chromate primer on galvanized metal prior to painting with good results fro adhesion, most specifically exterior house doors and chaing link fence. Local paint store steered me that way.
My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man!
1953 Chevy 3100 Shortbed
1965 C-30 Panel Truck
1963 C-20 Long/Fleet Pick-up California Black Plate
#217971 10/17/2006 1:51 PM
There are a number of primers out there that
will adhere to galvanized steel.
You can also use muriatic acid to cut the
zinc coating to accept paint. Put it on with
a brush, let it sit for a while and then hose
them off good with water.
Steve
'49 3800
'52 3600
'57 3100
#217972 10/18/2006 4:19 AM
Former Workshop Owner
It seems that I remember back 25 or so years ago, that my Dad applied household vinegar to galvanized rain gutters before painting. I think he then applied an oil base primer. I don't remember any problems with the paint not holding. Has anyone else ever tried this?
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#217973 10/18/2006 4:31 AM
I would just wash with muriatic acid, same stuff used in swimming pools, flush with water and a little soda. When dry, give them a coat of epoxy primer, let it flash and spray the color coat of you choice.
I have as sign on the front of my store made of 26 gauge galvanized that was prepped with muriatic acid and painted with oil base paint 10 years ago. Still looks new.
It used to be standard practice to etch galv gutters, ducts and other building stuff with muriatic or vinegar before painting. Besides, epoxy will stick to most anything!
#217974 10/19/2006 12:36 AM
My brother used galvanized roofing to skirt his house trailer. He used vinegar on it first, then painted with good paint. It lasted longer than the trailer.
I like old trucks
