3 members (KEVINSKI, Cosmo, ShopRag), 91 guests, and 9 robots.
Topics128,187
Posts1,057,212
Members48,465
How long did Gm use 6 hole 1/2 ton wheels after the 1954 conversion to open drive line.
They still do! grin
It's my understanding that they made the conversion to the open drive line with the '55 first series. :confused:
Becareful, todays 6 bolt pattern is different than that of the 50's. Current production C-T-C stud spacing is greater. Therefore, rims do not interchange stock for stock. frown
I used mid-eighties Toyota 4WD p/u wheels (which are 6 lug) on my '63 C-10. No clearance probs.
Not sure if that helps??
*** GMC ***
