1 members (Leo),
85
Mod | | | Forums66 Topics128,194 Posts1,057,261 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21779 06/09/2002 5:30 AM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | How long did Gm use 6 hole 1/2 ton wheels after the 1954 conversion to open drive line. | | |
#21780 06/09/2002 8:30 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | They still do!
#21781 06/09/2002 5:42 PM | Joined: Apr 2002 Posts: 36 Member | | Member Joined: Apr 2002 Posts: 36 | It's my understanding that they made the conversion to the open drive line with the '55 first series. :confused: | | |
#21782 06/09/2002 8:03 PM | Joined: Apr 2002 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 99 | Becareful, todays 6 bolt pattern is different than that of the 50's. Current production C-T-C stud spacing is greater. Therefore, rims do not interchange stock for stock.  | | |
#21783 06/09/2002 8:39 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | I used mid-eighties Toyota 4WD p/u wheels (which are 6 lug) on my '63 C-10. No clearance probs. Not sure if that helps??
*** GMC ***
