4 members (Gdads51, Jon G, cmayna, mick53), 93 guests, and 0 robots.
Topics128,126
Posts1,056,351
Members48,441
#217742 10/14/2006 3:26 AM
52 Chevy 3600....all original. Headliner is not broken, but is sagging in the front center. No holes in the roof. After sitting in rain, the headliner is very damp,in about a 12" circle and you can see the water line where this has been happening for awhile. It's the original headliner and not broken...yet. Where do y'all reckon this dampness/wetnees is coming from. Truck is sitting in the driveway when this happens so it's not blowing thru the windshield rubber. Can't quite figger it out.
Dash Riprocker
you must have a hole in the roof then... tap the top, see if it all sounds solid.
Another quality post.
Real Trucks Rattle
Does the truck have clearance lights? If so, check base gaskets. I think it doesn't because you would have thought of this.
Evan
Condensation on the inside of the roof?
Mine has the same problem - caused by leaky dried up windshield gasket. The old gasket was retaining water from rain or washing, then when driving air pressure forced the water in. The angled windshields forces the water in at the top.
Apprentice
Apprentice
Hello,
my 54 has a similar prob. I found out it was condensation forming on the inside of the metal roof. My roof is now bare metal, so I my plan is to insuluate the entire roof, then put in the new headliner. If I were you I'd get on it, becuase I left mine go for a while and now i have rust bubbles on the inside of the cab from the condensation.
Hope this helps you. Gman.
Sounds like the condensation problem. Thanks guys....I'll get to work on it.
Dash Riprocker
