0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | 52 Chevy 3600....all original. Headliner is not broken, but is sagging in the front center. No holes in the roof. After sitting in rain, the headliner is very damp,in about a 12" circle and you can see the water line where this has been happening for awhile. It's the original headliner and not broken...yet. Where do y'all reckon this dampness/wetnees is coming from. Truck is sitting in the driveway when this happens so it's not blowing thru the windshield rubber. Can't quite figger it out. Dash Riprocker | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | you must have a hole in the roof then... tap the top, see if it all sounds solid.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Does the truck have clearance lights? If so, check base gaskets. I think it doesn't because you would have thought of this.
Evan
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Condensation on the inside of the roof? | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Mine has the same problem - caused by leaky dried up windshield gasket. The old gasket was retaining water from rain or washing, then when driving air pressure forced the water in. The angled windshields forces the water in at the top. | | | | | Joined: Mar 2005 Posts: 19 Apprentice | | Apprentice Joined: Mar 2005 Posts: 19 | Hello, my 54 has a similar prob. I found out it was condensation forming on the inside of the metal roof. My roof is now bare metal, so I my plan is to insuluate the entire roof, then put in the new headliner. If I were you I'd get on it, becuase I left mine go for a while and now i have rust bubbles on the inside of the cab from the condensation. Hope this helps you. Gman. | | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Sounds like the condensation problem. Thanks guys....I'll get to work on it.
