7 members (2-Ton, Shaffer's1950, Otto Skorzeny, Gdads51, stoveboltgator, klhansen, Rusty Rod),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Took the 52 3600 in for a new muffler and tailpipe a few weeks ago. As I was backing off the rack, people started yelling to shut it off. The rubber oil inlet hose from the pan to the filter had gave out. Talk about luck! I went next door and had one made...about 5 bux. the guy at the parts store said I might ought to replace the return hose too. Figured to get around to it soon. Today, I stopped to see some buds and they wanted to see the original 216. I popped the hood and you guessed it....oil dripping off everything. Guess what else...oil filter return hose. Imagine that! I went to the same shop and had another one made....for anuther 5 bux. Check those hoses man! Cheap insurance. Dash Riprocker | | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | One more thing. The cause of these leaks was the hoses had dry-rotted right where they join the brass fittings. The return line was rotted on both ends. The truck last ran about 4 years ago and had sat in a field all that time. She's on the road and running good so far....luckily. Will post pics asap. Dash | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm glad you got it fixed before you pumped it dry.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 197 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 197 | Sounds like you had "the Big 'Bolter in the sky" looking out for you, Dash. That was really fortunate how both times you were in a place where you were able to catch it. Have a great day.
Neil 1940 GMC 1/2 Ton
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Would be a good time to check most other rubber parts as well, i.e. fuel lines, radiator hoses, etc... That's kind of what happened to my truck after sitting in a garage for 8 years before I brought it here and started using it. ALL that stuff had to be changed. | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | doesnt replacing all those rubber parts before you drive off go without saying???
i guess it's just as good to be lucky.
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Rusty, Didn't Napoleon say that he'd rather have an officer who was lucky than one who was good? John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I replaced my hoses to the filter but I'm thinking about taking the whole canister filter system off. On a 216 there's only about 10 percent of the oil that gets filtered anyways. So it seems like it's only there for looks. I only drive it 2 or 3 thousand miles a year, so a once a year oil change ought to be good. | | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | Strange stuff Steppenwood. I never heard that. Why is it you reckon that so little of the oil gets filtered? | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | Must be a bad year for old rubber. The same thing happened to my '62 not too long ago.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I had a similar situation a couple years ago. I just happened to be in town when my oil pressure sending unit failed. I shut it down, added a quart and limped it a couple miles to Johnson County Auto where they got me back on the road for a pittance.
delete my account and pictures
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | I often think of how old all the parts on these trucks can be... and still look good. My scariest nightmare are the rubber brake lines. The rubber line out of the gas tank could be disasterous too. | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | my 36 corn binder has 3 feet of rubber hose from the electric fuel pump to the carb, and another 2 feet from the pump to the fuel cell.... That is one of the better aspects of this truck. :rolleyes:
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Many engines have been damaged by these hoses, but I woudn,t take one off. It,s true only part of the oil goes through the filter but all the oil eventually gets filtered. You can see the difference on the dipstick. It,s, great when you are showing off your truck & you pull out the dipstick & the oil looks like it just came out of a can. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | First thing I replaced on my 47 jeep was its 3 different oil hoses. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Dash,are you the one I talked to about a front gravel pan at Ingles.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Copper tubing is always a good lasting alternative and insurance of sorts. Your local hardware store got all the parts/fittings you need for a few bucks. You can even go to the autoparts store, rent a tubing bender and flaring tool (free after returning) get flare fittings and be even safer than just compression fittings. | | | | | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | You guys are not gonne believe this. After replacing both hoses, I found the leak. A hole was rusted in the bottom of the filter housing. Go figger! Gonna get another housing tomorrow and try again. Oh well...it'll all be kinda sorta new when I get done. I've had guys tell me that only about 10% of the oil gets filtered anyway. Reckon it's even worth the trouble? Or reckon a man should plug the block and go back to 30 weight non-detergent? Dash | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | If I were you, I'd just fix that old canister, providing that the hole isn't to big.
I wouldn't go back to non-detergent oil but I agree that the low-pressure canister is almost worthless. I just drop a roll of toilet paper in mine and forgetaboutit....
| | | | | Joined: Mar 2006 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 28 | Ter- You are right about those rubber brake lines and fuel hose at the front. When I first got my truck the U-bolts on the rear end were almost completely rusted through so I had to replace those and while I was doing that bumped the brake hose and it just broke clear through (40 year old rubber!). Recently I started smelling gas in the garage and couldn't figure out from where. Well one day after driving the truck I went inside but forgot something in the garage, came out and there was a nice puddle under the engine compartment. Cracked rubber fuel line!
Needless to say check your rubber! 1965 Chevy Fleetside C10 If riding in an airplane is flying then riding in a boat is swimming... If you want to experience the element get out of the vehicle!
