5 members (Gray_Ghost, Hotrod Lincoln, klhansen, 2 invisible), 96 guests, and 1 robot.
Topics128,051
Posts1,055,729
#217422 10/10/2006 4:26 AM
What's the best way to get a stripped screw out. My carburetor, at some time, was overhauled and one of the brass plugs/screw doesn't have enough material to get a bite with a screw driver. I'm afraid to heat it and am a little leary to drill it out. What's your best method to get it out?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
#217423 10/10/2006 4:31 AM
well what i think i would do, would try to cut or file a slot in the head and get it out that way
1955 Chevrolet 3100 2nd
1954 International Harvester R-110
My Webshots Pictures
#217424 10/10/2006 4:35 AM
Tab Offline
I use a hacksaw to make a new slot.
delete my account and pictures
#217425 10/10/2006 4:37 AM
Tab Offline
if there is no room to get a hacksaw in there, use a cut-off tool.
#217426 10/10/2006 4:42 AM
use the right size screw driver. hold firmly in what is left of the slot. push down and turn cc to the point before the driver slips. lightly tap on the driver while repeating the above.
"It ain't a truck if you can't hose out the cab."
