| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | What's the best way to get a stripped screw out. My carburetor, at some time, was overhauled and one of the brass plugs/screw doesn't have enough material to get a bite with a screw driver. I'm afraid to heat it and am a little leary to drill it out. What's your best method to get it out? | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | well what i think i would do, would try to cut or file a slot in the head and get it out that way | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I use a hacksaw to make a new slot.
delete my account and pictures
| | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | if there is no room to get a hacksaw in there, use a cut-off tool.
| | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | use the right size screw driver. hold firmly in what is left of the slot. push down and turn cc to the point before the driver slips. lightly tap on the driver while repeating the above.
"It ain't a truck if you can't hose out the cab."
