| | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21736 02/26/2004 1:30 AM | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | I have a '64 chevy stepside, and I want to upgrade to disc brakes up front, and 5 lugs all around. I've bought a '75 for parts, and have taken the front end and rear end out.
My question is, is there any way to swap the rear end 'tubes' on either side of the center rear end housing? If I can do that, I won't have to grind off the old rear end's brackets and weld them to the new rear end. I think the tubes are pressed in. Can they be swapped?
Any help would be greatly appreciated. | | |
#21737 02/26/2004 3:29 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | What type of rear ends do you have? Are they identical except for the axle tube attachments? I don't think the axle tubes come out easy and you are probably better off removing any necessary brackets and welding on to your new axle. I just put a 14-bolt in my '55 out of an '89 3/4 ton and it only took about an hour with a cutoff wheel, grinder and air chisel to remove some spring perches and a few other attachments. The fit-up and welding took a lot longer. Pinion angle was the key. | | |
#21738 02/29/2004 12:47 AM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | The axle tubes are pressed AND welded into the center housing! I've swapped a tube on a motorhome rear end that was not available anywhere, and it's a real hassle. You'll be better off modifying the spring perches. You'd need to do a complete teardown on the rear end, drill/grind the welds out, push the tubes out of both housings, and reinstall them precisely in the right position, then reweld everything. I wouldn't do it again for twice what I got paid the last time! Jerry
#21739 02/29/2004 1:18 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | early classic sales the spring perches. | | |
