3 members (Donf, tclederman, 1 invisible),
72
Mod | | | Forums66 Topics128,181 Posts1,057,177 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 24 New Guy | | New Guy Joined: Sep 2004 Posts: 24 | First thanks for all your ideas so far they have all helped tremendously. MJ
doing a 51 3100 1/2 ton pu
how do you take out and replace the bearing with the horn wire on it in the steering column ?? the manuals say use a threaded bearing puller and I don't have it. thanks ahead of time . | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | it really is fairly easy at least mine was take the wheel off, use a screw driver to pry that bearing from the end of the shaft. you can possibly re-solder the (a) new wire to it. pack the bearing b4 replacing it the wheel removal will be harder than the bearing removal
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
