0 members (),
113
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I've notice several posts asking about flaring brake lines. I just happen to have to do some today, and thought I'd post some pix to show how it's done. First, the tools ,mines a professional kit, but the kits fom the flaps work similar http://rides.webshots.com/photo/2188171820092261295sexvyb first operation is reaming a bevel on the end of the tube http://rides.webshots.com/photo/2034722880092261295VJsClF next is clamping in the appropriate die, note that the end of the line is flush with the die surface http://rides.webshots.com/photo/2909677320092261295nflRjW then the upsetting die is used to start the flare by foling over the ned of the line http://rides.webshots.com/photo/2794117050092261295mYQGnS after upsetting die, the line is now partially folded in on itself, creating the double wall of the flare now the cone die is used to finish the flare, the folded part of the line is forced into the flare finished flare http://rides.webshots.com/photo/2971355310092261295HdcWDXhttp://rides.webshots.com/photo/2763082590092261295KySWjB I do appologize if my post is a little sloppy, I'm still learning how to do picture posting.
Bill Burmeister | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | Sweet.. that is how Rusty Rod does it too.. but Rusty uses an elcheapo kit.... does everything the pro kit does, except to get the TIGHT close bends!!
| | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | my 50 dollar kit from sears did alright except the flare seemed to be al little off center. i thought it was kind of weird. funny thing was that the clamp broke on the very last flare i had to do. guess i just got lucky. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | Thanks for the info, Bill. I've attempting flaring only twice. The first time, I failed to move the connections to the ends before bending, causing them to jig-lock mid-length. The second time, I made a wonderful line (with fittings on the ends!) but sadly, it was a mirror image of what I needed. I learned that you can't simply twist the line into submission.
I tend to make lots of "practice parts."
Bill | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | I have found that the cheaper kit does not have sufficient clamping force to keep the line from backing out during the process. I had to use a large vice to enhance the clamping force. I would not buy the cheap kit again.
By the way, the cheap version does not look like the real thing at all. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i took mine to a local brake shop they have a very expensive flairing tool it cost me $5 end i pre bent all lines and took the whole truck's set down and had it all done in 15 minutes my all new installation was a snap.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | I have an expensive flaring tool which I got in the late 1960's. I replaced all of my brake and fuel lines in the early 70's using this tool. I used Bundiflex tubing and got excellent results. All flares were 100% perfect. Fast forward to 2006....I needed to flare a new fuel line last month so out came the expensive tool which had worked so well years ago. Trying to flare modern day flex line was impossible. The tube just slipped down the clamp as I tried over and over again to get the first flare. Then it dawned on me that the tube they make nowadays is cheap and thinner walled than the old stuff so it just slips past the clamping device. I hate to throw the tool out but it is useless with the newer tubing. Just thought I'd add my experience so I might save someone else a lot of frustration. Guess I need to buy a new expensive flaring tool!
1948 AD Pickup
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | On my old flaring tool I was able to remove some material in order to get it to clamp down more.You might try it before tossing it-the way I looked @it I had nothing to lose. I had a similar problem using copper tubing on the water line to the dishwasher in my house-the tubing collapses instead of the comp fitting. I remedied it by buying a $10 flexhose. Brian | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | I wonder if there is a "metric" measurement on the new tubing? Ter | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Yeah Brian, I did grind off a little of the clamp at the meeting surfaces but it still did not work. And I was afraid if I ground down too much I would end up with pinches on either side of the tube or worse, the tube would oval out. But as you said, nothing to loose in trying it again.
1948 AD Pickup
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | My $3.00 retool tube flarer and my $20.00 FLAPS tubing bender work pretty good.
I'm better at flaring than bending, but the job gets done. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ter, there are metric brake lines, but they are used on modern vehicles and have a different type flare. It's called an ISO or "bubble" flare. Not compatible with the older style brake components. By the way, there's nothing wrong with using an inexpesive flaring tool. I have an old KD kit that does very well, though it does require some extra clamping force to keep the line from slipping.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | About 15 years ago, when I was 17, I bought the mid-grade flare kit from Snap On. The kit still sells for right around $100; hasn't gone up in price much at all since I got mine. It comes with a very nice tubing cutter, and directions. It is because of this kit that I enjoy doing brake lines so much! Really. I do. I've never had a flare split or crack, and they've always turned out well. I also have the expensive kit shown in the first post. It's nice, but the simple Snap-on one does the job well for me, and I typically use it.
Essential for the job is a good tubing cutter. You MUST have a nice square cut on the end. I also added a set of very small files to de-burr the ends (this includes round and tapered needle files to get inside the tubing). I also have one $65 tubing bender that will bend 3/8-inch line into a radius the size of a quarter. NOTHING can beat it for making good, easy bends for a factory fit and finish. I need to invest in two more of those; 1/4 inch and 1/2-inch.
If you buy cheap tubing tools from NAPA or other places, you'll always be frustrated. This is one of those jobs where good tools make or break (brake?) the job.
Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This is the flare tool that I used in the demonstation. It's a Snap-On/Blue point. It is a little expensive for the average 'Bolter. I use it in my work as it does any flare for late model cars. http://buy1.snapon.com/catalog/item...6&store=snapon-store&dir=catalog This one is the type that most of you will use. It's made by KD, and can be found at the flaps for about $20. It does a good job, but requres practice and patience to get good flares. http://www.kd-tools.com/2199.htm
Bill Burmeister | | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | you can try running a tap through the hole to roughten it up a bit more to grab the line.I was having the same problem with the line sliding throught, tapping the block helps, the real fix was i found a snap-on flare block and have no problems even with 5/16 line.. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I purchased a "Lisle #31310" flairing tool last week and attempted to do my rear axle brake line. I practiced on some old original lines with limited success. The old lines wanted to split, but the new line turned out OK. What seemed to help was to use pliers to hold the adapter and cone from turning in the brake line during the process. The new brake line seemed to be "softer"? Just my 2cents. | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | I must be doing something wrong, I've bent up two trucks worth of lines, including fuel with my cheapy Lisle one and didn't have any problems. Maybe a half dozen redos. I cut the tubing with a tube cutter, deburred, filed it so it's perfectly square with a slight chamfer,clamped the whole shebang in a big vise, made sure the die tip was well lubed with brake fluid, and slowly formed the flare making sure the die remained square. So far after about 5,000 miles, no leaks.
Bob | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Alright, Denny! Your flares look just as good as the factory done ones, maybe even a little better. Just don't forget to put the fittings on before you flare.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | I checked out Fedhills website. The tech page has a lot of info on nuts and fittings. http://www.fedhillusa.com/?page=tech2
Joe -------------------------- '67 Chevy C20 fleetside, 250 inline, 3 on tree, heavy duty clutch and brakes, heater, steel bed floor ----------- "Tighten until the stud snaps, then back off half a turn."
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | OK Denny cough it up!!! We want details on this Limy tool, where you got it and how much it cost! I ordered that $100 kit from Snap on the other day. However from all I have read it probably won't work any better than my Home Depot job.
~Jim
| | | | | Joined: Jan 2007 Posts: 38 Apprentice | | Apprentice Joined: Jan 2007 Posts: 38 | Thanks Denny, this has been a problem for us for some time. Seems you've found the right piece of equipment. Thanks for all the info! | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Denatured alcohol would be a better choice for cleaning, most Brakekleen type products are petroleum based solvents. Brian | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | brjr51 - Hi Bob,
Which Lisle flaring tool do you use? The one for around $50 or the one in the orange case for around $115.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Dennis, I use the cheaper one I got from Farm & Fleet. I've found the secret to be a square cut on the tube, making sure the die starts and remains square to the tube through the forming, and some brake fluid for lube. The problems arise when the die starts to angle as it's being tightened. I tighten it very slowly and keep a close eye on it. If it even looks like it's starting to cock, I stop and correct it. Mind you, this tool only works on the mild steel line, I wouldn't even think of trying stainless.
Bob | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | all chlorinated solvents are nasty stuff. for the environment and for you. many states have some type of ban in place.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I used to worry about contamination & cleaned brake things w/denatured alcohol, haven't really given a darn in years(can't make money doing that)& I just use Brakleen now. I have seen many, many cars where power steering fluid or ATF or even motor oil was put into the brake system-I just replaced the master(always) & calipers maybe, bleed system w/brake fluid. One shop had a pressure bleeder, worked great but fits very few cars nowadays. You can't clean every line, nook & cranny, ya cannot make a living as a tech doing that. They always seemed to be OK. Easy to tell if too much petroleum has messed w/the system, the little gasket on the master cyl cap will be about 2x its normal size. I got no clue as to what is in your brand of Brakleen, I just assumed it is petro based, some around here is even diesel fuel(Autozone brand)w/a propellant!!! Brian | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thanks Bob,
I was at Sears last night and all they had was a double flaring tool for about $25. I am kind of scared of a cheap tool. Searsman said if I didn't like it, bring it back. I told him I would think about it and left.
So, I am thinking of the Lisle tool. But am unsure if anyone sells the tool in the Dallas area or if I should order it from them off the internet. I don't care for a $500 tool. I will probably only do my two trucks and believe it would be cheaper to get the pre-bent lines from one of the venders. Well, then there are the gas and vacumn lines. HUMMMMM
Time will tell.
