2 members (2-Ton, farmallb),
62
Mod | | | Forums66 Topics128,021 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 49 | I'm trying to figure out what I need for replacement hubs for my '64 suburban. The front axle has 44-5F stamped on it. The hubs that are on the truck now are Warn, with no external bolts. The transmission is 4 speed with reverse left and down. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The "44" should mean that it's a Dana 44, not positive though. Any parts store should have hubs on the shelf. Your transmission is a SM420. Scott | | | | | Joined: Sep 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 49 | 48bigtrucks,
Thanks! Phoned local parts store, guy looked up Mile Marker and said they had hub that fit 60-68 1/2 tons, but he did not know if it would fit my '64 Burb. Price, $332. and change! I have a shop manual for 1963 and the '64 suppliment. The '63 manual says the front axle is a Spicer 44-5F. I contacted Mile Marker and the guy there wasn't even sure which hub would work. I have been trying to get an answer to my question fot months and have yet to find anyone that can tell me for sure what hub I need. The hubs that are on the truck now are Warn. They work, scarred some. I was hoping to replace them. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Spicer and Dana are the same, the name is the only difference. Also, if the hubs will fit a 1/2 ton pickup, they'll fit a 'Burb, as the chassis parts are the same.
Bill Burmeister | | | | | Joined: Nov 2000 Posts: 6 Junior Member | | Junior Member Joined: Nov 2000 Posts: 6 | | | |
