1 members (stlcardinalsguy), 71 guests, and 1 robot.
Topics128,030
Posts1,055,430
Members48,422
#21708 03/25/2004 11:33 AM
Since finishing my truck last year I've had a real problem with my gas pedal foot almost catching fire (or at least feeling like it could). I put on about 6,000 miles last year so that was a lot of less than pleasant experiences. Along the way I added two extra layers of insulation and installed cruise but the exhaust manifold was still making my firewall right next to my gas pedal hotter than h..l.
Enter Pat Moore from Moore Coatings in Waverly, NE. Has some stuff called ceramic paper. Visited his display while showing my truck at World of Wheels here in Omaha a couple of weeks back. Supposed to conduct close to no heat at 1000 degrees. Plan to pick up a couple of square feet of the stuff this weekend. $6 a square foot so not cheap but if I can cool my foot down, it will be worth it. Will report back.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#21709 03/25/2004 4:51 PM
eek
I'd like to hear more about this ceramic paper and whether it does any good or not. Be sure to keep us posted on your progress with it!
Heat in these old trucks is a real problem!
#21710 03/31/2004 3:46 PM
Well, I bought 2 square feet of ceramic paper at $6 a square ft.--$24. Installed Sunday--just put it on top of the peel 'n seal, under my insulation pad--and took my test drive yesterday. 30 minutes on the road--hot manifold--and no noticeable heat from the floorboard or firewall where I installed it.
Pat said it is used on the floorboards and firewalls of NASCAR vehicles to keep the heat down and yes, the stuff really does work. I may have to open the valves to my heater now and then to warm up the cab--I've had them closed since last spring.
By the way, the place is Moore Power Coatings, Waverly, NE, (402) 786-2887. www.moorepower.com.
1956 Chevy 3100
#21711 03/31/2004 5:25 PM
56: Thank you for the great sight got the e-mail address written down for future reference. popcorn The Truth is Out There (Thank you)
