3 members (Phak1, TUTS 59, Hush),
108
0
Mod | | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Has anyone here had experiences they will kindly share regarding the use of powder coat for carburetor castings? I would like to do it but I have concern with heat induced dimensional issues.
I understand that epoxy paint is good for this application but I desire a clear coat. Is there any such thing as clear epoxy paint?
Thanks for your help.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | You don't need clear epoxy, just use automotive clear top coat paint, it will hold up and will not dissolve with gasoline. I have glass beaded my Rochester "B" carbs and the clear works fine, they still look like new carbs. | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | I've had good luck powder coating carbs. I've only done two though. An old Rochester 1 barrel, and a Holley 4 bbl. The porosity of the castings will give you fits though. It holds all sorts of contaminents and will bubble and blister the powder coat. It took two tries on the main body of the Rochester to get acceptable results. The prep on the first failed attempt was, media blast the carb, clean with metal prep, prebake, reblast, reclean and coat. After blasting the powder coat back off, I repeated the above steps and achieved good results. An awful lot of work for an old carb. I think I would follow chevman32's advice.
John | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Thanks for for sharing your experiences. I think I'll try coating a junk carb to see what happens then turn to Eastwood diamond clear if it don't work out.
