1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#217051 10/06/2006 2:06 PM
Has anyone here had experiences they will kindly share regarding the use of powder coat for carburetor castings? I would like to do it but I have concern with heat induced dimensional issues.
I understand that epoxy paint is good for this application but I desire a clear coat. Is there any such thing as clear epoxy paint?
Thanks for your help.
Mike Barnes
1950 GMC 1-ton pickup
#217052 10/06/2006 5:22 PM
You don't need clear epoxy, just use automotive clear top coat paint, it will hold up and will not dissolve with gasoline. I have glass beaded my Rochester "B" carbs and the clear works fine, they still look like new carbs.
#217053 10/06/2006 5:53 PM
I've had good luck powder coating carbs. I've only done two though. An old Rochester 1 barrel, and a Holley 4 bbl. The porosity of the castings will give you fits though. It holds all sorts of contaminents and will bubble and blister the powder coat. It took two tries on the main body of the Rochester to get acceptable results. The prep on the first failed attempt was, media blast the carb, clean with metal prep, prebake, reblast, reclean and coat. After blasting the powder coat back off, I repeated the above steps and achieved good results. An awful lot of work for an old carb. I think I would follow chevman32's advice.
#217054 10/09/2006 1:31 PM
Thanks for for sharing your experiences. I think I'll try coating a junk carb to see what happens then turn to Eastwood diamond clear if it don't work out.
Mike Barnes
