| | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I have seen references to a product called "Peel and Stick" on this board in relation to noise deadening and as a heat shield for the cab of a truck. I believe it will work for heat, is that right? If so, how well does it work? I have looked at the web site and it shows this product used in large pieces. Can it be gotten in smaller sizes? How thick is it? Have any of you that have used it had good luck with it? Thanks for letting me quiz you on it and for the help! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | Joe, you can buy the Peal & Seal same stuff at Home Depot & Lowes I think it's about 8 inch by 15 foot roll. I used it in my 46 and it sure does work. Love your truck. Used to have a 37 coupe in the 60's. Good luck Ed http://community.webshots.com/user/46metal | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Its worked for me. I bought mine at a local roofing supply. Wound up using about 3 rolls. 12"x33' roll for about $30 | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have used it, the only problem I have seen is the edges want to peel off a vertical surface in the summer heat(closed up windows & out in the sun) if there is nothing else to hold it up. I used it under the OE type firewall pad, it has worked fine, but on the rear cab wall behind the tank the edges peeled back-but good heat-a/c type duct tape on the edges held it back on well. No one looks back there but me. Deadens sounds better than it insulates against heat, I got 3ftx100ft roll @a builders supply store for about $100,,Brian | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Thanks for the replies guys!! Nice truck, stea!! Cool color!! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Hi Joe, it was nice meeting you at the Ballpark swap meet.
I bought both the peal and stick and insulation (the insulator) from JC Whitney. They both came in sheets of approximately 3 by 5. I put them under my rubber mat in my 55 2nd. The only problem I had was that I had to cut the insulation over the hump in the middle of the floor so the gas peddle had enough room to work correctly.
Dennis -there is nothing stronger than the heart of a volunteer-
