4 members (Phak1, dt235sd, NorCal52Suburban, Wayne67vert), 85 guests, and 1 robot.
Topics128,049
Posts1,055,546
Members48,425
#21687 04/20/2005 2:38 AM
I'm pulling my 235 to detail it, not rebuild it. (The compression is 135LBS each +/- 5 LBS) If I loosen all of the bolts and only use to attach the cherry picker, should I plan on pulling the head and changeing the gasket? Yes I am cheap!
Thanks for the advise.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#21688 04/20/2005 5:37 AM
If you loosen more than a couple of head bolts, you need to replace the headgasket. Best if you can take out one on each end. After you put the engine back in, retorque all the head bolts, in the proper sequence.
Fred
52 3600
69 C-10
#21689 04/20/2005 12:33 PM
Thanks Fred. That's the kind of advise I need. The shop manual assumes that you're going to pull the head.
#21690 04/20/2005 5:45 PM
Johnny, I have pulled several chevy 6's by simply removing a bolt from the lower part of the thermostat hosing and using a longer bolt through a link in a chain. The other end of the chain i attached to a longer bolt through the last bolt on the intake mainfold. I haven't lost one yet. This doesn't involve any head bolts. Redcoat
#21691 04/20/2005 9:39 PM
I've used the same method as redcoat many times. Just be sure the longer bolt you use is a grade 8. On the aft end I use the last stud and put the chain between the manifolds.
#21692 04/21/2005 1:09 AM
Thanks guys. I already have the manifolds off and plan on removing the water inlet part of the thermostat housing anyway. Your way makes sense.
