0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Hello Stovebolters,
Quick question - With the heat riser spring removed, does the counter balance on the heat riser valve weight the valve in the open or closed position? The valve on my manifold rotates freely. Thanks!!!
1948 AD Pickup
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There is no open or closed position. In the normal position (where yours is sitting with no spring)exhaust is deflected toward the bottom of the intake manifold. In normal operation the spring heats and moves the flapper to send the exhaust directly out the pipe. Both positions are open as far as exhaust flow is concerned. | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | I know, the terminology is confusing to me. So what I mean to ask is: with the spring removed, is the flapper inside the exhaust manifold allowing heat into the intake manifold for warm-up proceedure (cold engine) or is it in the position to route all of the heat into the exhaust (hot engine).
Thanks for your very quick answer to my question cletis!
1948 AD Pickup
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | cletis is right all though when the engine is warm the "Valve" is considered to be open. The weight will be at the lower position (open) when it is free to do so. The by-metal spring will overcome the weight when cold and "close" the valve. In either case the exhaust remains open. The exhaust air is simply deflected to the bottom of the carb. when cold.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | With the spring expanding when warm - the exhaust bypasses the intake pipe.
So without a spring there its always bypassing the intake, as only a cold spring will redirect the exhaust upwards...
A quick look inside the shop manual illustration would also confirm this. | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Thanks Everyone for the replies! I have a much better understanding of the heat riser now thanks to you all. Much Obliged!
1948 AD Pickup
