0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#216709 09/29/2006 9:12 PM
Hello Stovebolters,
Quick question - With the heat riser spring removed, does the counter balance on the heat riser valve weight the valve in the open or closed position? The valve on my manifold rotates freely.
Thanks!!!
1948 AD Pickup
#216710 09/29/2006 9:19 PM
There is no open or closed position. In the normal position (where yours is sitting with no spring)exhaust is deflected toward the bottom of the intake manifold. In normal operation the spring heats and moves the flapper to send the exhaust directly out the pipe. Both positions are open as far as exhaust flow is concerned.
#216711 09/29/2006 9:38 PM
I know, the terminology is confusing to me. So what I mean to ask is: with the spring removed, is the flapper inside the exhaust manifold allowing heat into the intake manifold for warm-up proceedure (cold engine) or is it in the position to route all of the heat into the exhaust (hot engine).
Thanks for your very quick answer to my question cletis!
1948 AD Pickup
#216712 09/29/2006 9:47 PM
cletis is right all though when the engine is warm the "Valve" is considered to be open. The weight will be at the lower position (open) when it is free to do so. The by-metal spring will overcome the weight when cold and "close" the valve. In either case the exhaust remains open. The exhaust air is simply deflected to the bottom of the carb. when cold.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#216713 09/29/2006 9:52 PM
With the spring expanding when warm - the exhaust bypasses the intake pipe.
So without a spring there its always bypassing the intake, as only a cold spring will redirect the exhaust upwards...
A quick look inside the shop manual illustration would also confirm this.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#216714 09/29/2006 10:45 PM
Thanks Everyone for the replies! I have a much better understanding of the heat riser now thanks to you all.
Much Obliged!
1948 AD Pickup
