1 members (Mike Roache),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | hey im replacing the bed in my truck and i swear i only saw 2 cross sills when i took the bed off, and then the reinforcement strip also, but on Mar-k it says you need 3? can someone tell me if you need 2 or 3. thanks in advance.
patrick | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Not counting the end pieces, there's three, two long ones and a short one that goes between the wheel tubs, Scott | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | i just looked at the parts i took off, and i took of 3 standard cross sills, the reinforcement strip, and the rear cross sill. so i guess theres 4 if you count the shorter reinforcement strip. | | |
