7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 8 Junior Member | | Junior Member Joined: Jul 2006 Posts: 8 | Can anyone help guide me replacing the rear drum brakes on my '58 half ton? Maybe you can refer me to a website? Thanks, I've got oall the parts, just need talked through hooking up the park brake. Roger | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | My mom lives in Caldwell, ID, and I'm going to be in the area in a couple of weeks with my wife. I think it would be cool if I could stop by and check out your 58. Mine's still at the paint shop (the guy's as slow as molasses, but he does very nice work from what I've seen and heard); so, I won't be driving it this time. I'll send you a PM. I know that it's a couple of weeks away, but I could bring my shop manual with me, if you don't already have one  .
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Aug 2004 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 141 | Roger,
The parking brake system has a pivoting lever half-way back that hooks into a notch on the frame on one end and connects to the parking brake cable from the front on the other end. In the middle of that lever is an attachment link that holds two adjustable links that run to each rear brake cable. The cables, of course, run inside the brake drum and connect to the bottom of the parking brake expander.
Good luck! | | |
